Rich_Mar
Sep 11, 2020Explorer
tire pressure
do you run the max pressure in your tires as written on the sidewall? I have the Endurance, and it states 80# psi. Seems to me you need to take the outside temperature into consideration. I an relu...
fj12ryder wrote:TxGearhead wrote:Maybe if you're running ST tires, but I run my Sailun "G" rated tires at 95 psi rather than the 110 psi that is the max pressure. Makes for a much smoother ride. And with 2000-2500 lbs. per wheel I don't need to run the max pressure.
Always run trailer tires at max pressure no matter how many axles.
