Sinecure
Mar 17, 2014Explorer
The Voltage 3600 is a triple axle fifth wheel. Also the OEM tires are Load Range E, which are rated around 3400 +/- lbs each and require 80 psi, not 45 psi.
Back to the OP, the general consensus seems to be if you want peace of mind, replace them. It isn't IF, but WHEN they decide to blow out and you can count on it being the most inconvenient time possible.
About Fifth Wheel Group
19,034 PostsLatest Activity: Mar 11, 2026
