garysol
Aug 10, 2014Explorer
I am not that far from you. My camper is stored in North Ridgeville. Anyways I went through the same confusing tire search as you are now. After reading many many....many threads on this subject I upgraded to a G rated tire. I went with the Sailun S637 in a 235/85R16. At 110PSI it is rated to 3,750lbs each. Do some research on these. If your interested and would like to see a set mounted up so you can do some measuring just let me know.
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 03, 2021
