I have always rotated the tires on our previous campers. I have also had the tires balanced. Is this something I need to continue with the new fifth-wheel?
Balancing beads in the tire will help compensate for the unbalanced hub assembly. And you won’t need to degree the rim to the hub each time you remove for inspection /maintenance.
