RideSlow's avatar
RideSlow
Tire rotation 2 axle
I was surprised to see that my spare is mounted on a wheel that matches the other 4. Since the TH has relatively low miles, (and we are trying our best to fix that) what would you do for keeping all 5 tires in rotation?
  • I rotate front to back on my triple axle, but I don't rotate the spare in. Probably should.
    Tires that don't get used, rot faster than tires that do get used.
  • On a trailer, I don't think it's THAT important to rotate tires. But, some folks do. It not so much the pattern, as long as it's the same pattern and you do at regular intervals. Determining miles on a trailer is a little harder than in a car or truck with an odometer. But your best guess would be every 1000 miles, 2000 miles, 3000 miles, as long as you are consistent with your intervals. Anticipate 40 thousand miles on your tires? Then you'll need to rotate them 5 times so they'll all be equal. That means every 8 thousand miles rotate. Take your own option for a pattern: click here.
