- Gray_FoxExplorerThanks for all your replies I think I will leave them be they all look good.
- wilber1ExplorerI never have but might on this present 5th because it is about 900 lbs heavier on the street side. I'll only do it if there is a noticeable difference in wear between right and left sides.
- 3oaksExplorer
SabreCanuck wrote:
That's all that counts! ;)
I generally rotate every couple of years, depending on miles...
I see I'm on the smaller majority here and don't know WHY I do it, but i always have and it works for me, so.....
Carry on. - Dick_BExplorerWe rotate ours (TT) but mainly to include the two spares in the rotation. Tires that just sit (spares) lose some of their properties so incorporating them into the mix helps maintain their longevity.
- Jack_Diane_FreeExplorerNo rotation on past 6 trailers over the years with no problems. Current trailer have had for 5 years and no rotation, no problems with wear. Not something personally from my experience is required.
- The steering, braking, turning, acceleration are the same... no need to rotate.
All these factors are different on the tow vehicle and so rotation can extend tread life.
As noted previously it is easier to know where an alignment issue is if the tires are left in place. - SabreCanuckExplorerI generally rotate every couple of years, depending on miles...
Carry on. - kennethwoosterExplorerReally see no reason to rotate tires. Besides 5th wheel trailers I've had a lot of stock trailers as well as flat bed trailers for moving equipment. Never had a need to rotate.
- OaklevelExplorerNever................unless you put alot of miles on the trailer......
35 years own three two axle trailers have never rotated tires always age out before any serious wear. - Cummins12V98Explorer IIIIf they look good do nothing. Wear issues then get the problem fixed.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 12, 2026
