Greying
Feb 19, 2015Explorer
tire size for 5th wheel
Hi, I am looking for some help with tires size. I have a 2005 or it could be 2004 Salem 24ft 5th wheel. The tires on it are 205-75-15 on a 5 bolt rim. The previous owner said it had the wrong axles which caused the tires to wear out. The axles have been replaced and I want to replace the tires. The unit weighs 2750 kg dry. The tires on it now are good for 1260lbs. To me this is too low. I was thinking of a 205-75R-15 in a c load range or even a 225-75R-15. What do the experienced guys/gals say? Currently the tires on it are not radial. What is the proper way to figure out what the proper size is? what about the axle. Maybe I need to check that too.
Thanks
G.
Thanks
G.
