spud1957ExplorerAug 26, 2014Tire SwapLooking at changing my 235/80 16E tires for a set of 245/75 16E Michelin Ribs on my 5th wheel. For those that have done it, anything I should be concerned about with the very slight difference in size...Show More
Me_AgainExplorer IIIAug 27, 2014I see people put LT265/75R16E on GM 6.5" wide rims all the time and that is out of spec. You can really see the side wall roll into the bead.R250's on a 6" wide rim will be 100 times better than any current ST tire available. If you have 33" or more center to center on your axles, then get the 235/85R16E's.Chris
