Does anyone have any information from the tire manufacturer why we should use trailer tires instead of truck tires on trailers? If all the side wall ply and tread ply are the same, what is the differe...
After reading all the post's I went with the Michelin XPS rib LT235/85R16 on my 2006 HitchHiker II, which I recently purchased. The manufacturers tire size tag says to use the LT not the ST like the trailer had on it when I bought it. My concern now is that with the LT235/85R16 is quite a bit larger in diameter than the ST235/80R16. Consequently I now only have 1/2 inch clearance between the tires! Is this enough clearance? Thanks
