threehendersons
Aug 27, 2013Explorer
Tire Traker pressure monitor - possible interference issues?
We have a 2013 Ford F250 diesel truck with the GPS/navigation package and a 35' 5th wheel. Installed a Tire Traker pressure monitoring system but having trouble getting the unit to update pressures. The pressures will update when I hold the monitor and remove and then replace the sensors but no further update occurs, even after waiting for 30+ minutes. Tried moving the sensors to the truck tires to see if distance was the problem but still don't get a pressure update.
Called the Tire Traker rep and they said that a booster was needed and likely the problem was interference with the GPS/navigation or diesel engine. This was news to me and wanted to hear if anyone else has had a similar problem. I was trying to stay away from installing a booster and also wondering if that is really the problem/solution?
Thanks in advance for any guidance/suggestions.
