amxpress wrote:
So are you saying that my Maxxis ST tires when inflated cold to 80 psi are not designed to handle the incresed pressures when hot?
I also find your comment about heat, not loads, cause most blow outs. Where may I find these statistics for reference?
to answer your question.. the correct answer is no. especially when the roads are hot, the tire pressure needs to be close to max psi.
this is because low pressure allows the tire to flex more... flexing causes heat... and it is absolutely true that low pressure is the cause of more tire failures than the load or over inflation... with the exception that the load on a tire, heavy load or otherwise, causes flexing of the sidewalls, which builds heat.
this is why when a maximum load is placed on a tire, the maximum pressure is recommended.... and less load, less pressure is required.
on some forum recently, (maybe this one) I wrote something similar to "a tire that goes flat from punctures or from being so low on pressure that it pops off the bead in a tight turn, may be able to be repaired many times over, but any tires that go flat from heat have to be replaced every time"....
over loading is nearly equivalent to over inflating, and its low on the list of tire failure causes, with the exception that overloading causes flexing of the tire, and the less internal pressure the tire has in it, the quicker it builds heat and fails.
so in a sense, the load does have a lot to do with it, but overloading is more relative to the amount of pressure in the tire, rather than what is stamped on the tire.
the main difference between the ST tire (Special Trailer) and a LT tire (Light Truck) is the sidewalls in the st tire is stiffer, so it stands up better and is designed to flex less. low pressure allows it to flex too much.
so keep it aired up and carry the load without having a blowout.
for those that like to run a lower pressure, or have a habit of not checking their tire pressures often, the LT tires will be a better option.
you can run LT tires on a trailer, but its illegal to run ST tires on a truck....
and in addition, for anyone that does have a blow out and doesnt have a spare left, you can limp many miles (50+) on a flat tire without damage to the rim if you keep your speed to less than 10mph... once the vehicle speed reaches 11-12mph, the flat tire will begin to come apart and will soon leave the rim riding on the road surface, rather then the flat tire.
this is directly due to the heat generated by the speed of the flexing...on a hot road surface, the tire rubber may get so hot that it sizzles when you spit on it, but if you keep the friction low, it will hang together.
