BB_TX wrote:
Buy a long reach 4 way lug wrench. One of the four will fit. The longer the better. And the long handles give extra torque to remove those stubborn nuts. And the “spin factor” speeds things up. Works for your truck also.
First, not all 4-ways have same size sockets. Plus for something you hope to never use, 4-way takes up a lot of room.
OP do you have a socket set? Can you ask somebody that does for help? Try each socket until you find the right size. Go to Harbor Freight (or if you can find in pawn shop) by that size deep well
impact 1/2 in drive socket, a 6 inch extension, and a long breaker bar. Yes, likely you will not need the extra strength of impact socket, but the 6 point is good, you have room on the wheel to use, and even quality names brand sockets break. The impact grade is less likely to break.
BTW, if the bar does not give you enough leverage to loosen the nuts take it to a hardware store, buy a pipe as long as, and that will fit over handle. Telescoped out, you can get 50% more power, and take little more room.
