SHExplorerApr 12, 2020Tires & DOTSo...been dealing with tires and tire posts for many years and have a plethora of experience with them. However I have a new challenge. Dealers seldom carry my tire in stock and they must be order...Show More
Old-BiscuitExplorer IIIApr 12, 2020Swap from GY 614's to Sailun S647'sGreat tire, as good/better then GY 614s AND a whole lot cheaper priceOrder from dealer and TELL them if tires are older then 6 months....return them cause you will not accept them.Simple.....your $$$ your decisionDealer should meet your NEEDS.....otherwise use a different dealer.
Related ContentBuying tires? Check the DOT codes...Help figuring out DOT tire codeDOT Age of TiresDOT code on tiresDOT Endurance Test for ST Tires NOT same for LT Tires
