720Deere
Nov 27, 2013Explorer
Crazy Cooter wrote:
17.5's with a good tire is the best option and Goodyear G614's being an adequate and more affordable solution. Xps ribs or any other LT tire in this size don't have enough capacity for your unit.
The 3010 is only a 14,000 GVWR trailer. While I will agree that 12,168 worth of tire rating is cutting it close, I wouldn't go out on a limb and say it is not enough. G614s are probably the best bet, but the rims are probably not rated for 110 psi so you will end up replacing the rims anyway. If I had to replace the rims, my move would be 17.5 tires which will far exceed your needs, provide the best peace of mind and even reduce rolling resistance which should help fuel economy.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
