Any good tires out here ??
Yes, but for us to give you some good brands to choose from that the forum actually uses and recommends we need help with some actuals such as the trailer GVWR and the axle ratings.
Scaled weights come in 20 lb increments so I'm guessing the 4050 lb number is a axle rating ???
Thats 2025 lbs per tire at a minimum.
A 16" ST E has 3400-3500 lbs capacity. These tire are way too much tire for a 4k axle .... if thats the case.
Need some help or your going to get lots of guessing and wrong recommendations.
