TexasChaps wrote:
PyroTekRob wrote:
Ok, my 05 Weekend Warrior needs tires.   My current tires are in good shape, but 2 are over 4 years old, and the other 5 are just about 4 years.
The local Americas Tire has Hartland ST tires, can order Carlisle.   But I have also been told to get LT tires.  So if I change to LT, what would work current are ST 225/75R15.    I think LT only come in 235, could I fit 235s on my triple axle trailer without rubbing?
Maxxis UE168 n bravo
http://www.maxxis.com/catalog/tire-227-bravo-series-ue-168-n
LT235/75R15
available from online tires.. where i got mine
this could work, has a higher load rating ( by nearly 200lbs ) and is 0.6 inches larger in diameter
I have a worse situation than you in that my hauler tires are 14 inch and I basically have almost no choice in tires. I found the UE168n by way of a friend who has a Casita.. they are very popular with that crowd.. I have dual 3500lb axles fitted with the 14 inch.
the tire is a rib type and I have over 15000 miles on them without issue. for me, the load rating is much safer, the ST gave me 1760 per tire, the bravo gives me 2270 per tire.. in your case a Goodyear ST is rated at 2150lbs.. the bravo is rated at 2337.. they will fit a rim from 6 to 7 inch..  worth investigating in my opinion.
4 Wheel Parts seem to be a dealer for those tires.  Ill check that out, thanks.
