abc40kids
Mar 05, 2015Explorer
Mile High wrote:abc40kids wrote:
Goodyear G-614's will be put on.... I'll contact Keystone just to see if the wheel will hold 110psi or it might be stamped on the back of the wheel. I'm wanting to ask Keystone what they were thinking in the first place.
I tried with the dealer but I'd haggled them to death already and being a tire dealer I knew I'd be using the g-614's anyway. I had them check to see if the max air was put in and rolled out, 90 min ride never over 55.
Amazing how the G's look compared to the E's and as I left the dealer I looked at the Grand Design Solitide, another heavy 5er and found the same E tires.
You can probably find your wheel here
Tredit Tire and Wheel
Thanks, I called them and they said my wheel is rated at 3750 and will hold the 110psi. The tire I want to use is the 235/85r16 Goodyear G-614 which is only an inch taller. I've got 6 inches between my tires now, I should be fine. Thanks again...
as I think Keystone still uses them. If you spot it, you can look up the spec. They won't give you psi anymore, but if its rated for 3,750 lbs load its rated for 110psi. Some of the 3,500 lb load wheels are only rated up to 90 psi.
About Fifth Wheel Group
