Schnizzy's avatar
Schnizzy
Tires on a 5th wheel and aggravation
This is not a request for help, rather an experience to share.
Tenth year in our 3rd 5th Wheel. We had 2 blowouts in the first due to old tires, my fault.
This 5th wheel is less than 5 years old and we had 3 blowouts, explosions on the way from Maine to Florida this year. The damage to the camper was almost $500. DOT dates are 5 years old. They have less than 5000 miles. A 4th tire blew up while attached to the back of the RV, not even on the ground.
These are China bomb tires, Castle Rock. We tried to claim a warranty but so far, we might see $210 for 2 tires. We submitted photos of DOT numbers for 3 tires. The distributor responds the tires exploded because they were overloaded. Yep, that explains why one did not leak on the back of the camper, rather it freaking exploded, as in gun shot exploded.
The point is , when you buy, demand the best tires. It is no fun crawling around under a camper when you are 74, it is 29F outside and the 18 wheelers want to give you a sway.
If a tire blows up, take lots of photos including the brand of tire, size, damage, DOT number which is only on one side, 4 numerical digits, as in 0519, 5th week year 2019.
My RV dealer in Maine reports the new RVs are arriving with good tires. Good news.
Advice to RV dealers; do not send a camper down the road with China bombs. Know your customers, they will not think highly of you if you sell RVs with junk tires.
  • GY ENDURANCE, simply try to find a NON ROAD HAZARD claim. You most likely will NOT. Stellar record since introduction in early 2017. Expensive??? Don't thin k so.
  • If you =have= to use ST tires, there =are= decent ones out there. GY Endurance are some of the better ones, though more expensive. I'm not a GY fan, but that's what I ended up having to put on my KZ when I needed to replace the OEM tires. So far, I'm satisifed with them. Could have saved about $100 on a set if I could have had them in time before a trip.
    Lyle
  • While I feel your pain as a 10 year RV'er you got to know you need quality tires by now. Don't count on the dealer to provide quality tires. ultimately it is your knowledge and responsibility to avoid china bombs.
    If you were a newbie I'd understand but as a 10 year RV'er and someone who has played the RV blowout game you got to be savvy enough to protect/save yourself.
    Preventative maintenance and keen awareness is key to successful R$V ownership if you slack in these areas it will come back to bite you.
    I have been bitten by tires before. While I agree OEM tires have improved.
    It still maybe necessary/wise to replace tires on a brand new RV.
    The dealer will not tell you that but 10 years of experience will.
    You are new to the forum and my comments may appear to be a bit course and blunt that is not my intent.
    If you read these forums you will find cheap tires and blowouts is an old reoccurring issue that can be only be resolved by knowing your towing parameters and weight and by buying premium tires.
  • Tpms are a must. Post will be moved to more suitable forum.
