klr650goldwing's avatar
Apr 04, 2018
Tires one more time
I know this topic comes around frequently, but I just did searches and couldn't find specific information. Very soon I'll be replacing tires on a 12,000lb, 36 foot 5er with 16 inch wheels. I'm a Michelin guy on my cars/pickups, but not sure about the 5er. I will gladly spend the money for the best tire available. Which tire would you recommend?
  • IMHO XPS Ribs are the best E rated tires out there. Ran them for over 6 years on a 2008 Jayco Eagle. 245/75/16. I don't think I've ever, ever, ever heard of anyone having a problem.
  • The LT E XPS Ribs or the Bridgestone R-250 are both a all steel ply carcass commercial grade tire at 3042 lb capacity and are the holy grail for 16" wheels and 5.2k lb and 6k lb axles. The R-250 is quite a bit lower priced. One isn't any better than the other.
    Now if your trailer has 7k lb axles then the Goodyear G614 RST in a LT235/85-16 G at 3750 lb and 110 psi.
    Or the Sailun S637 ST235/80-16 G at 4080 lbs at 110 psi. Make sure your trailers wheels are approved for 110 psi.
    Both tires are a commercial grade all steel ply carcass and are tops for heavy trailers requiring 7k axles.
    When replacing OEM tires on a the tires capacity should meet the trailers axle ratings.
    And of course do your homework on proper wheel well and between the tire clearances for your particular trailer. We can guess but a good truck tire dealer can assist you with clearance issues.
    edit; added sailun brand
  • donn0128 wrote:
    XPS Ribs or Transforce
    Save a couple hundred bucks and get Bridgestone Duravis R250. Virtually the same tire as the XP Rib but +/- $50/tire cheaper. Never seen a single bad word on them here in > 10 years of reading.
    Lyle
  • My current tire size is ST235/80R16. So with that information, would everyone still make the same recommendation?
    Lyle
    I agree on the R250's. On our Cardinal that had similar weight to OP's, I ran XPS Ribs and R250's.
    R250's.
    Your not passing along all the info we need so were guessing your trailer has 6k axles. If thats the case those LT E at 3042 lbs capacity work great.
    You need at least 33" center to center on the axles for Ribs or R250's, and about 3" above the tire, which will be 1/2" closer on the top. Chris
    Tire Size Calculator
    The LT E XPS Ribs or the Bridgestone R-250 in 245/75R16
