Poppy_s_5th_Whe's avatar
Feb 15, 2016
Titan vs. Kodiak?
I'm planning to upgrade my drum brakes to an electric/hydraulic disc brake setup.
Has anyone done the research on which setup seems best or are they on par with each other?
Thanks
  • Thanks for the response guys. Looks like a lot of folks running the Kodiak brakes but no feedback on the Titan brakes. They do have a bigger presence in the boating community it seems so maybe there aren't that many in 5th wheels.
    I have almost no room in my front compartment so placement of any actuator will be a challenge in there.
  • Actually my Titan actuator is quite compact and I mounted it in the front compartment. No problem.
  • I have the Kodiak system with Carlisle actuator and it is a nice compact unit and works great for us. I understand the Titan is a little more robust of an actuator (larger piston, etc), but requires some more room to install. I've seen them on the side of the frame.
  • We had Mor Ryde install ours when we had independent suspension put on.
    They put on the Kodiak's, and they are amazing.
