blacktopExplorerSep 04, 2015to grease or not to greaseI have one of those greaseless plastic rings on the pin box. I'm thinking that I should still grease the pin. What do you use, white grease, bearing grease, WD-40 or something else?
TXicemanExplorer IISep 04, 2015WD40 is not a lubricant in any way shape or form. WD is for water dispersant.
Related ContentGrease gun/ grease recommendationsGreasing the hitchhitch greaseGreaseWheel Bearings - re-grease?
