Veebyes
Mar 23, 2016Explorer II
Actually it is quite easy to knock em down to a few models.
Start with freshwater tankage. If it is less than 80gal cut it from the herd. Anything less is good for a couple night wekend, not much more unless you run to the CG restroom/shower. I am thinking drycamping.
Next easy one to reduce some more is the galley layout. So many have very little counterspace like you get with an island or "U" shaped galley.
Make a decent size fridge a must have.
Set your maximum length & stick to it. Your 35' length is a good one if you plan to do SPs & NPs.
Eliminate the known junk builders from this much shorter list.
By now you should be down to less than 6 possible models.
Start the search & don't be swayed on "such a deal" on a model you don't want. You will regret it.
About Fifth Wheel Group
