psford
Oct 31, 2014Explorer
cdlaine wrote:
...crew cab, towing a mod. large Sunnybrook 5ver with the attached
single axle trailer (loaded with a quad 4-seater). Sir... your
toad trailer is whipping around like crazy with every lane change,
and bouncing up and down enough to cause concern that your trailer
(with under-sized wheels / tires ) may cause a catastrophe.
I gave you wide berth... the Granny looking thru the steering wheel
did not. Navigating the Phoenix metroplex is tough enough...your
set-up is unsafe....then again, I'm pretty sure you can't even visualize
your towed trailer.
If anybody here knows this guy...he might need a heads up... of course
you probably know him in New Mexico, Tenn., Montana, New York, Missouri,
Colorado, Michigan etc.....
Charles
Just curious, was there no way you could motioned to him, or waved , whatever to maybe get him to pull over to tell him. Its sounds like it needed immediate attention , not a post on a forum hours or days later. From the sounds of it somebody needed to do SOMETHING !!!!!
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 29, 2025
