2btowed
Mar 30, 2016Explorer
Installed a Magnum 2500w inverter/charger when my trailer was new in 2006.It has had no problems and will run micro with TVs on,Dish etc.Charges up to 120 amps and has 3 charge levels plus you can manually equalize your batteries.My first 6 costco 6v lasted 5years,my second set of 4 costco batts lasted 6years.I wired it so all plugs are hot when inverter on,makes it simple.Has feature to start genny when batts low but never bought the adapter for it.Has remote panel to make things easy.Yes it was pricey,but has been the best addition that I have done.The only thing you have to watch out for is that it will blow out 12v phone chargers,since it goes over 14.4 volts and 15v sometimes to finish a charge.I got the modified sine-wave,and will upgrade to a pure sine wave if replacement is ever needed,since some electronics like UPS will not charge at present time.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
