Monty-RobExplorerJun 14, 2017Toilet bowl doesn't hold waterThe toilet bowl in our fifth wheel does not hold water after you flush and add a little water to the bowl. It slowly goes down. Is there an easy fix or do I need a new gasket?
laknoxNomadJun 15, 2017Spa / Pool lube also would work, if you have a pool and have some around. Stuff you put on pool filter gaskets.Lyle
Related ContentSwitching toiletsWater pump?Why no hot water?Wanting a Bidet for my Thedford toilet.toilet bowl water
