cummins2014
May 26, 2020Explorer
RCMAN46 wrote:
This tool box is in a short box Chevrolet. I chose it as it has room under the tool box so I can carry full sheets of plywood or sheet-rock. I also store things under the tool box like tire chains and a set of 12 ton jack stands when towing.
The tonneau cover starts at the tool box. It is in the rolled storage position now. The tonneau cover clears my hitch when deployed.
So far after 15 years of towing with two fifth wheel trailers clearance to the tool box and rolled up tonneau cover has not been a problem.
Looks like you need one of those extended run gas tanks for that generator ,you could eliminate at least one of those gas cans. They are very nice , with at Honda generator you have, plus not having to fill that often.
On edit, it appears you have a hose running to that gas can on the right, so do you have an extended run system ??
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
