Alpenliter wrote:
If you do a lot of off season camping in cold weather, I would suggest an Olympian 6000 Catalytic Heater. It uses a fraction of the propane that the furnace uses, and no battery power at all. Use the furnace to quickly heat the trailer, then use the Cat to maintain the comfort level. Also, the addition of a Morningstar 300 inverter allows you to run most everything off battery without the battery sucking draw of the 2000 watt inverter. Good luck. And have fun!
That heater is a great idea. What LP source do you use; small campstove bottles, 20 gal bottles, hose from RV bottles?
Never mind, saw that covered in the Amazon description and would get a regulator/hose to go with it. I like the suggestions of 10 lb tank as I am not sure how to run the hose in from outside.
