Kevin_Todd
Jul 19, 2015Explorer
Tow question
Got a '02 Dodge 2500 4x4 with 5.9 HO Cummins, 6 sp, 3.73 rear, Camper special package. We just purchased a 2016 Jayco Pinnacle 38FLSA and we're picking it up shortly. Big fiver. How do you think my ol...
rhagfo wrote:Old-Biscuit wrote:Kevin Todd wrote:
Figured that would be the answer...Picked it up in Cincinnati yesterday morning and brought it to West TN. No problems. 250K miles on the old girl and she did great. As far as my tranny, I've pulled everything from backhoes to the big fivers and she's still going strong. I'd be more concerned about that GM if I were you....course it looks like you trade regular....
From that response it's obvious you know you are way overloaded, don't really care and was looking for someone to say OK
Well you are overloaded.
A 2002 vintage 2500 4X4 is NOT in the same league as 2015 2500
You are overloaded but will not go across a scale cause you don't want to face reality
Old-Biscuit, you are correct, but the 2nd gen RAM/Dodge 2500's with the Camper package are greatly under rated!!
I tow a 12,360 GVWR 5er currently at 11,000#+ GVW, this puts the TV at 10,000#+ usually right at 10K. I still have over 500# of "stock" rear axle rating to spare, which is based on the stock tire size of 245/75-16E 3,042# rating. If the rear axle rating was corrected for the Camper Package tires 265/75-16E's at 3,415# ea. I would have a rear axle rating of 6,830#. The package also included 3500 springs, that is all that is back there, and the rear sway bar.
The camper Package in 2001 didn't change a single weight on the VIN sticker, the VIN has the same weight ratings as the non camper package.
I have know doubt that Kevin's tow was just fine, as at at about 2,200# pin on mine Kevin may have been a bit down in the rear, but not much, and likely dry well with in the tire ratings.
The camper Package basically was the 2nd Gen SRW 3500, which was not an option until 2003.
