Coach-man
Jan 29, 2016Explorer
To the OP, would the TV be your only driver? If that will be a daily driver, parking an maneuvering is a big issue, and can not or should not be ignored. With proper tires, you should be good to go up to 13K - 14K for your rig. However you will be at max in that range! You state you will buy both rig and TV, why not settle on your rig first, then determine what you would need to haul it with? If you buy the TV first you may limit your options!
About Fifth Wheel Group
