davonelson wrote:
I need advise on the best route to tow my 36ft 5er from Pensacola, FL to Newport, RI. I can follow I-81 or I-85/95. The western route is preferred but I am concerned it will be mountains and tougher towing. Help!
Growing up in AZ, I'm used to mountains and long grades. If you're on an interstate, you shouldn't see grades more than about 6-7%; no problem with equipment in good repair. Just take it easy. Here, we have several 7% grades that are 7-8 miles long and many others that are 1-3 miles. Just keep your speed down and use engine braking as much as possible. Personally, I'll let my FW push me up to about 65, then stab the brakes fairly hard to slow down to about 55, then let it creep up again. So far, I've not had any heating issues by doing this. On the way uphill, I try and pass when possible, but usually resign myself to running with most of the semis, which can be as slow as 25-30 mph if I get stuck behind a heavy one. I know I can't run much over 45 anyway, but if the opportunity to pass presents itself, I'll jump over and pass the truck. Can take up to a 1/2 mile, so I'm =real= cautious when I do so.
A lot of guys here seem to avoid 95 whenever possible...
Lyle
