Well I bit the bullet, went out a bought a new 5th wheel and need some advise. What tow/ truck should I look into, the dry load is approx. 11298lbs, the GVWR is Rated at 15000lbs. What truck would y...
You can probably get by with a 350/3500 SRW, but a dually is going to be better suited to that load. As far as gas vs. diesel, I'm not sure that any of the 350/3500 SRW gas trucks are rated to tow that heavy and if you go dually, diesel is really a no brainer.
