rayecklesExplorerNov 28, 2013Tow VehicalWell I bit the bullet, went out a bought a new 5th wheel and need some advise. What tow/ truck should I look into, the dry load is approx. 11298lbs, the GVWR is Rated at 15000lbs. What truck would y...Show More
whskExplorerNov 29, 2013above 10000 lbs you are in dually territory-I went RAM CUMMINS DRW and it is a towing machine!-good luck with your choice-whsk
Related ContentTowing lights issueTow Vehical Batteriesengine chips for tow vehicalChevy Trailblazer, good tow vehical?Tow Ratings
