Well I bit the bullet, went out a bought a new 5th wheel and need some advise. What tow/ truck should I look into, the dry load is approx. 11298lbs, the GVWR is Rated at 15000lbs. What truck would y...
LMAO......most 150/1500 trucks are rated to tow over 10,000 lbs these days with half the models rated at more than 11,000 lbs. I guess there is no use grossing 80,000 lbs with the Peterbilt when it would be much safer at 65,000.
