Well I bit the bullet, went out a bought a new 5th wheel and need some advise. What tow/ truck should I look into, the dry load is approx. 11298lbs, the GVWR is Rated at 15000lbs. What truck would y...
For me - that would be 1-ton SRW SB territory. Our prior Montana with 15,500 GVWR 3,000 lb. pin weight was a perfect match to our F350 SRW for years and the number were right on.
