rayeckles
Nov 28, 2013Explorer
Tow Vehical
Well I bit the bullet, went out a bought a new 5th wheel and need some advise. What tow/ truck should I look into, the dry load is approx. 11298lbs, the GVWR is Rated at 15000lbs. What truck would y...
Atom Ant wrote:john&bet wrote:?? Let's take it a step further, let's just eliminate the 3/4 ton. Why de-rate a perfectly good SRW 1-ton with lighter axles and springs ;)
My opinion is that there should be no such thing as a 1 ton srw. Thier tires are the same so thier contact point with the road is the same as a 3/4 ton. JMHO.
