Cummins12V98
Mar 13, 2016Explorer III
avvidclif1 wrote:Cummins12V98 wrote:
Thanks NC!
The RV has a GVWR of 21k. It actually weighs 23k. The axles weigh 17,500#. The tires are GY "H" that rate at 4,806# per tire. I will be at MorRyde in May to add the 2" riser so that will transfer some weight to the truck. May possible upgrade the IS suspensions at that time.
I hope your numbers are backwards. Towing 2k over GVWR is not smart.
No they are not backwards. I could swap out the 21K TrailAire Kingpin to a 23K MorRyde Kingpin and all would be well. But I did replace all the 5/8" bolts holding the kingpin to the frame with 3/4" frame bolts. I am 750# over the 8K axle ratings and as said may upgrade something at MorRyde. Also my tires are more than strong enough.
About Fifth Wheel Group
