- Cummins12V98Explorer III
transamz9 wrote:
rhagfo wrote:
transamz9 wrote:
If you are planning on drag racing get the 4.10 if not the 3.73 will be more than enough gear an better all around gear.
If pulling a 23,000# 5er 4.10's are nice to get rolling, and hills.
Like I said before, I pull with 3.42's and yes there is a difference but I have never had an issue " getting going ". I have actually had my traction control kick in a couple times on damp roads taking off at lights that are on hills. Be leave me, 900 lbft of torque has no problem getting 23000 moving or keeping it moving.
I don't think we are talking modified trucks here. 900TQ is not stock for your truck. I can't remember do you have 68RFE or Aisin? - transamz9Explorer
RustyJC wrote:
What does your 5th wheel weigh? You're apparently talking about 23,000 lb GCW since you're towing with a SRW truck. The OP is probably going to be in the 32,000 lb GCW range once he's loaded with everything.
If it were me and (like the OP) I were going to tow a 22,000 lb 5th wheel, I think I might listen to those of us who are pulling the late model DRVs and other 5th wheels in the OP's weight range. But, that's just my opinion....
Can you do it with 3.42s? Yes - Cummins12v98 did, but notice when he changed trucks, he went to 4.10s. I've towed with 3.54s in a 2nd generation Ram - biggest mistake I ever made! That's why I ran 4.10s in the 2002 Ram as well as in the 2011.
With the 4.10s and the double overdrive 68RFE or Aisin (both have almost identical 6th gear ratios), 65 MPH in 6th gear is ~1750 RPM, so 6th gear is useful for towing, downshifting on grades is minimized, driveline stresses are lessened for a given wheel torque, you have the advantage of 6 versus 5 useful gears for towing and a lower overall 1st gear ratio which eases torque and heat loading on the torque converter, etc.
Rusty
No sir, I tow at 28,000 combined. I completely understand all the pluses and minuses of the gears. With my set-up I lock it in 5th and have vary few downshifts @ interstate speeds. I'm not telling the OP to get 3.42's I'm saying 3.73's would be fine. - Cummins12V98Explorer III
Texas Roadrunner wrote:
Thanks so much for your help, folks. This is really helpful information. Haven't heard much about the Ford 350 duallys. Anyone with experience pulling a really heavy fiver?
Do your self a favor and look the other way! Go to a full timers RV park and you will see mostly RAM's, GM's then not a lot of Fords. Same goes for Independent RV haulers.
CP4 pump warranty denial is enough to stay away! - Cummins12V98Explorer III
Cummins 12V,
Thank you so much for your help, this is just the kind of information we need. We really appreciate the help. Wish we could go with the 373 rear end but we probably should go with the 410, shouldn't have any issues if we do that. The gas mileage will probably be not quite as good as we could get with the 373, but it is the sensible thing to do. We were averaging 10.5-11 with the Denali pulling our 36' MS. Thanks again!
If you want the 3.73's I'd say go to it. I tow 20,000 (28,000) combined with 3.42 an run some pretty steep grades on the back roads around lakes and never one time felt I needed more power.
I would agree with you up to 28K combined the 3.42's work well. My 11 HO had 3.42's I towed in 5th at 60 with rpm's about 1,750 the same as 4.10's in 6th at 60. The only issue I had was getting the load rolling on a grade. Up to 28K get the 3.42's with the AISIN you will be very happy. Over that forget the 3.73's and go AISIN and 4.10's.
It really makes a HUGE difference with the 4.10's and AISIN getting the load rolling with a HEAVY load. - Cummins12V98Explorer III
Cummins 12V,
Towing heavy I really don't think the 3.73's would do better than the 4.10's since the 4.10's are really in the sweet spot at 1,750 at 60 in 6th. Solo the 3.73's would get a bit better but at this level who really cares?
You are welcome! - RustyJCExplorer
Rusty - transamz9Explorer
Like I said before, I pull with 3.42's and yes there is a difference but I have never had an issue " getting going ". I have actually had my traction control kick in a couple times on damp roads taking off at lights that are on hills. Be leave me, 900 lbft of torque has no problem getting 23000 moving or keeping it moving. - rhagfoExplorer III
If pulling a 23,000# 5er 4.10's are nice to get rolling, and hills. - Texas_Roadrunn1ExplorerThanks so much for your help, folks. This is really helpful information. Haven't heard much about the Ford 350 duallys. Anyone with experience pulling a really heavy fiver?
- transamz9ExplorerIf you are planning on drag racing get the 4.10 if not the 3.73 will be more than enough gear an better all around gear.
About Fifth Wheel Group
19,025 PostsLatest Activity: Sep 17, 2025
