Bob Bo wrote:
Cummins12V98 wrote:
Truck will "pull it just fine" but with a 20-25% pin that a 5er can easily have I HIGHLY suggest the 3500 LONG BED SRW with AISIN!!! Don't forget the towing package with the pucks and then since you will have the best truck for the job buy the best hitch a B&W. You WILL be more than happy with both.
If you really want the icing add the Factory Rear Air Ride.
The new truck as the 5th wheel prep package/puck's, and the rear air ride
Aisin transmission??
I tow a 16K 5th wheel with a truck with the same ratings. Your Montana has a higher dry pin weight. I suggest you use the lightest hitch you can find and keep the load in the trucks bed down to keep with in the trucks 7K RGAWR.
Hope you got the Aisin, did I already say that?
Chris
