Aridon's avatar
Aridon
Tow Vehicle Question (year recommendations)
Folks, could use some advice from people with more knowledge on the topic of tow vehicles than I have.
I know the DRW 1 tons in the relatively recent past have been upgraded considerably. If I were considering a used truck to tow a:
Grand Design Momentum 395
Momentum 395 Stats
Dry weight: 15,400
Hitch weight: 3,400 ish
GVW: 25,000
What years would I be looking at to be able to tow that with a DRW 1 ton from Dodge or Ford or Chevy?
Anything I should know about those years in particular (years to avoid, specific issues with components, new year for engine type etc)?
Thank you for time and knowledge.
  • Thanks folks, I don't know how I screwed up the GVW on the fifth but it being 20k instead of 25k makes a huge difference in what can and can't tow it.
    Appreciate the help.
  • If you go dually they should all handle the job. I'm only acquainted with Ford. Having owned a 6.0 6.4 and now 6.7 I definitely would only get the6.7 which is 2011 up. I have a 2014 6.7 and DRW. I love the current truck. It will handle your rig.
  • 2013 or newer RAM/Cummins/Aisin/4.10's. True Medium Duty combo. 2015 or newer with factory Rear Air Ride is a GREAT option. I have that combo.
    I tow 33K combined, the truck has performed great in all weather and mountain conditions. Trans temp 165-172 no matter the conditions. Cooling easily in check even on 14 percent grades.
    9,750# on the 4 rear tires, truck rides level with the factory rear air.
  • Pretty trailer. The specs say it has a 20,000 GVWR, not 25.
    I know my 2012 RAM with max tow is rated at 19,xxx.
    The challenge with buying a newer used diesel truck is you don't end up saving much cash. They just hold their value too well. You won't spend much more buying new.
  • GM was substantially upgraded in 2011. I wouldn't go older than that.
  • Any of the three, Fords model year 2012 or later, I think Dodge upgraded theirs in 2013. Not sure about GM
  • Ram 3500 DRW 6.7L Cummins, Aisin trans 4.10 rear end. That combo should be rated to 30K pounds.
  • I'm only familiar with Ford, I unfortunately have a 6.4 which is B5 limited while most stations have up to B20 fuel depending on the calendar and govt regulation. If your buying used Ford diesel get a 6.7 2011 or later.
