neal10a's avatar
neal10a
Tow Vehicle question
I am looking to purchase a new one ton TV. I am not a brand loyalist and after evaluating Ford, GM and RAM which all have fantastic specs for 2020. However, does anyone know if either of those mfg's offer a GPS system that are tailored for trucks instead of cars for route planning that take into account height, width and weight of the truck and trailer.
  • My 2015 Chev came with the factory navigation system. Never again. The cost of one update will buy a stand alone with free lifetime updates.
    B.O.
  • I know it's all the rage now....in-dash nav systems, but just be aware that to up date them from time to time to the latest maps may cost you. I have seen $140 for each up date.
    From Edmunds .....Updates: The maps on factory systems are typically as current as the vehicle's model year. If you want to update the maps, you need to purchase a memory card or, for an older vehicle, a DVD. These can cost $75-$200.
    I like Garmin's with life time map updates.
  • The answer is "No" to your original question. If you want a GPS that is set up for towing (overhead clearance, weight, length, etc.), the Garmin RV or Dezl units are your best bet.
    Rob
    The Garmin Dezl 770 will meet all your needs and then some. i.e voice command allows you to just use your voice to make changes as you drive, the 7" screen makes it easy to read as you are driving down the road, Garmin tech support is great.
