REM13 wrote:
I would like to give a heads up to those taking their vehicles to a dealer or other shop for servicing. In the past year on two different occasions when I've taken my 2012 Silverado 3500 Duramax in for servicing and the chassis was not greased at the time the oil was changed. The first time was at the dealer where I purchased the truck in Canada and the second in the USA where I'm vacationing. Both times I specifically asked for a grease job. I was alarmed both times and brought the servicing gap to the attention of the servicing manager. Both managers expressed that it is supposed to be a part of there servicing procedures. If an owner is expecting their vehicle to be greased it may not be for thousands of Kilos/miles and it could result in premature wearing of parts such as ball joints which can be a dangerous condition. I suggest checking after servicing for greasing or do it yourself to make sure it's getting done.
Same issue with my local dealer. Plus, when taking a look underneath after paying to have all fluids changed I saw the trans filter on there that I had installed at 5000 miles.
Return trip to the dealer got me a chassis lube AND a new trans filter! Plus an apology!
AND I personally checked to make sure the fluids had all actually been changed!
Makes a good case for doing it yourself!
