SoCalDesertRid1
Aug 22, 2016Explorer II
If you need more than 3400 lbs load per tire in a 16" wheel diameter, you need 285/75-16E's, which are rated 3750 lbs per tire.
I had custom heavy duty steel 16x8 wheels made that are rated 4000 lbs per wheel. I had to go custom because I could not find any 16" wheel available with a weight rating greater than 3500 lbs, back in 2007. I had them made by Stockton Wheel, in California.
About Fifth Wheel Group
