Dayle1
Mar 19, 2017Explorer II
DSteiner51 wrote:PNW_Steve wrote:
Hey Everyone,
I am considering moving my 5th wheel hitch to another truck. The challenge with this truck (E450) is that it has a 10' flatbed.
I cannot mount the hitch directly over the axle unless I cut almost 2' off of the bed. Not a good option.
The obvious alternative is to move the hitch back far enough that the trailer clears the back end of the bed. I know that this is NOT ideal but
I have little clue as to what the down side to this move other than reduced tow capacity. Given that I want to tow a 14k trailer with an E450 I am hopeful that the weight won't be an issue.
What other concerns should I have?
Thanks.
S.
Been there, done that... 11 ft flat bed, 30,000 lb trailer, no problem. Makes the front slightly lighter but nowhere near as much as a bumper pull. takes off the front axle approx what a Diesel engine puts on extra over the gas and adds it to the rear. Makes for a puller in soft soil or snow.
I have towed gooseneck/5th wheels with the hitches 9 inches forward to 2 foot behind the axle and heard all kinds of claims from experts who knew it all. Smile, shake your head and walk away. Trying to reason is a waste of time especially when on the clock and time is money.
I agree 100%, I have seen a number of rigs setup that way for transient workers like welders , etc. It would take a very heavy fiver to impact front axle weight on an F450. Also, the Reese Sidewinder moves the pivot point back 2 ft behind the truck axle and no owner has reported sway issues even on SRW trucks. You won't have a tailgate, but you can notch the back corners of the flat bed and you can minimize how far back the hitch needs to be for clearance.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
