DazedNConfused wrote:
Does that mean the truck can't handle it? No. You will likely be under your rear axle rating if you stick to a trailer with a gross of 12,000lbs or under. But will you be over GVWR? Yup...sure will if you approach that much trailer. Will the truck care? Probably not. Will the DOT care if you were sent to the scales? Yup...and they'll be happy to drain your wallet of all remaining cash.
- DNC
Could you detail what a state weight enforcement officer would be ticketing one
for.
* Being over federal bridge weights - not likely
* Being over 600(or whatever your state allows) pounds per inch of tread width - not likely, as this is higher than most LT tire ratings.
* Being over the Max weight at xx inflation mark on sidewalls - some states have that in their codes
* Being over the paid tonnage in some states - your mistake
* Having an unsafe looking load - again your mistake
So what is it you think they are going to use to drain ones wallet, as they do not drain hotshot drives wallets that tow a lot more than 99.999 percent of RVers.
Chris
