So what is it you think they are going to use to drain ones wallet, as they do not drain hotshot drives wallets that tow a lot more than 99.999 percent of RVers.
Like the California CVO Commander said in the email we keep posting from time to time: (snipped)
Section 1085(d) of Title 13 California Code of Regulations prohibits
the loading of tires above the maximum load rating marked on the tire, or if unmarked the maximum load rating as specified in the applicable Federal Motor Vehicle Safety Standard, or in a publication furnished to the public by the tire manufacturer. This would most likely happen in the case of a pickup truck towing a large fifth wheel travel trailer, as those types of trailers tend to transfer a larger portion of their weight to the last axle of the towing unit causing that axle to exceed the tire load limits."
The tires on a pickup are not the 500-600 lbs per inch of width size the commander is talking about.
