rhagfo
Mar 26, 2019Explorer III
RobWNY wrote:
My 2017 3500 Ram SRW Gasser has a payload capacity of 3900 pounds. Your 3113 pounds seems low for a one ton truck
Well I test drove a 2016 Ram Tradesman diesel with Aisin on a dealers lot, it had over 4,000# payload from the yellow sticker. The reason is that the MAX GVWR of a Ford F350 SRW is 11,500#, MAX GVWR of a Ram SRW is 12,300#, so Ram starts with a 800# advantage.
Before you listen to those that say just bag it and go, look at what the loaded weight is on rear axle and make sure you have enough TIRE!
If you daily drive a F350 Crew Cab Long bed, going to a DRW would not be that big of change.
Back to Max 5er towing, has to do with pulling not carrying. As pointed out before it is not just RV's and that max is for the base level trim package AKA stripper model.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
