romore
Feb 16, 2016Explorer II
We had contact with our old Vanguard, that one hurt the wallet. The current Prowler clears but not by much. Many newer trailers have the corners cut away to provide clearance. If you are unsure measure from the pin to the outermost corner of the trailer below cab level. Now stand in the box of your truck of choice and hold the end of the tape at a point in the center and 2" ahead of the axle center line. Swing the tape through an arc, if you get contact you want a sliding hitch or be very very careful when turning.
The newer '1/2 tons' can tow that much but you need to be mindful of payload. You have around 2,000 lb on the pin plus a 200 lb hitch. Add the family and the dog you are pushing the limits of any F-150/2500.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 25, 2026
