rhagfo wrote:
NC Hauler wrote:
jffnkrn wrote:
I apologize in advance for some duplicate info from the past, but I need some help clarifying a weight issue. My truck, 2010 GMC Sierra 4X4 HD2500 with the extended cab, standard box 3:73 gears. Towing capacity of 10,000lbs. GCVWR of 16000 lbs. actual scale readings with full gas and passengers is 6840 lbs. front axle is 3760 lbs. and rear axle is 3080 lbs. We have determined that towing a fifth wheel with a GVWR of 10500 lbs. or less is very doable. So here is the thought. Instead of keep looking for a light weight fifth wheel, am I ok to purchase one with an unloaded vehicle weight rating of say 9000 lbs. and add my 1000 to 1500 lbs. of stuff? This would be even if I purchase a unit with a GVWR of say 11,500 or 12,000. I know I kinda beat this do death at an early time, can't find the posting, probably 6 months ago. But we are getting closer to March / April our financial purchase time frame. Thanks for your help, I hop I have provided enough info. Jeff. OH Good Luck & Be Safe ! ! !
What engine, gas or Duramax /Allison combo? Are you sure GCVW is only 16,000#?
Please do yourself a favor and no matter what you tell yourself about what you'll load the 5er to, PLEASE ignore "dry weight" and go by GVW of the 5er when figuring what your truck can tow. Use 20% of that to figure pin weight, (better safe than sorry)...
I would think that a 2010 GMC 2500 would be have no problem towing a 5er with a GVW of 10500#....I owned an 03' 2500 ext cab/short bed/4X4/D/A and towed a 5er with a GVW of 12,000#, but that was with D/A, and it only comes with a 3:73, thus the reason I asked if your truck is equipped with the Duramax...16,000# seems low for that truck or am I missing something.
You are missing that based of the OP statement, he is likely running a 6.0 with 3.73 gears. Could he move that 12,000 GVWR 5er with the TV, likely until he came to the first real hill!!
This is not a case of the tail wagging the dog, just that likely not the correct running dear to move the load.
Ok, I was wondering why GCWR was so low...I had a D/A with 3:73....I haven't kept up with Chevy configurations since 07.5', thus the reason I was asking, and made my statements based on "my guess"...and "IF" it was D/A.....
Don't know much about newer 6.0, but having driven one years ago, opted instead for the 8.1 while I was still running with gas engine...
