rhagfo wrote:
AH64ID wrote:
Looking at the weights I am going to say it's a 6.0L gas truck, which does put the tow rating at 10,000 and GCWR at 16,000. 4.10's would bump it to 18,500. What I thought was interesting was that going to a 3500 (SRW or DRW) doesn't change the GCWR.
I agree with Coach, the floor plan is very important so make sure it's not a compromise too far in either direction.
GCVWR is a function of the power train and not the ability to carry the weight. This is why changing to a lower gear ratio with the same engine and trans increases the GCVWR.
Correct, but typically a 3500 will have a higher GCWR with the same drive train than a 2500. For my MY it's a 1,000lb difference, which isn't much but a difference none the less.
GCWR is more about acceleration and maintaining speed than anything else.
