pcaffrey wrote:
New to this forum and have no experience with 5th wheel units, have towed TT's for many years.  Here is the question, truck is 2016 Chevy 2500 HD, 6.0L 6 speed, 4.10 gears.  Looking at a Larado 30 ft bunkhouse 5th wheel, 2006.  Wt 8445/11500.  Bunkhouse is a must.  Truck towing capacity is 14200.  What if any issues am I likely to encounter.  Thank you.
First off, check the =payload= numbers for the specific truck you're looking at or own.  Yellow sticker on the door pillar driver's side.  An 11,500 GVW FW is likely to have anywhere from 2,000 to 3,000 lbs on the pin at GVW, that that's =much= more critical to the setup than is the "tow rating".  Yes, the GVW #'s are a worst-case scenario and you'll likely never hit GVW, if you pack smart, but you just might find yourself in it one day, and want to be safe if you do.  Don't forget that the payload listed on the sticker is for 1 150 lb driver and full fuel.  Add the hitch, wife, kids, pets and "stuff", and all that comes off the available payload for the pin.  If you can, see if you can find others that own the exact FW you're looking at and have real-world weights on their setup.
Lyle
